Originally Posted by tordur
...where I live, the only petrol available from the gas stations is unleaded octane 95... I remember this being a bit unlucky when I had my '06 WRX, since the manual clearly stated the car should only run on octane 98. Should this affect anything on which model-year I choose to purchase?
At oem boost levels (11.5psi) you'll be fine with 95, as long as the 95 is either motor octane or (r+m)/2. If 95 is the research octane, then you may have to drive out of your area to find some 'real' fuel to run it...
