If your ball joints are okay just take it to get an alignment. Usually camber and caster are going to be fixed with adjustment of the asentric bolts near your control arms. so if everything is pretty good like the ball joints then an anignment should not cost that much like around 30 dollors. But ask around like mrnikeleye and some other supra gurus they will tell you the best thing to do.
