lost of power at full throttle??
I have a mk2 with 7mge swap. Everything is good. The only problem I’m having is At full throttle it would loose power. Like the car is shut off. Then when I let go of the throttle and give it half throttle everything is good. It runs fine until I full throttle it. And the other thing is. Between 2 and 3 thousand rpm. It would bog out. When it goes pass 3k. It would run fine. It’s the same in every gear. I tried Putting 2 other tps on it. Still the same. If you know what the problem is hit me up... thanks..
