Old 10-21-2007, 05:01 PM   #2
mrnickleye
mrnickleye's Avatar
Read this first:
http://www.toyota-supra.info/forums/...ead.php?t=8072
What engine do you have?
Ge? perhaps the coolant hoses to/at the throttlebody are leaking. Even the throttlebody leaking?
Possible heater hose leak at the back of the head. Or its that fitting or its gaskets.
This is from IHATEHACKS.....Those 3 14mm allen head bolts right next to each set of spark plugs (1 0 1- 1 0 1- 1 0 1, 1= spark plug 0= 14mm allen head inbetween the plugs) hold coolant. Do not take those out unless you have coolant in your spark plug wells. I've never seen or heard of those 3 leaking though, so I wouldn't worry about them.
Those bolts are under the #3 gasket that runs down the center, and keeps debri out of the sparkplug area.
