Thread: spun bearing
Old 10-22-2007, 11:44 PM   #1
91 Supra
91 Supra's Avatar
91 Supra is on a distinguished road
Default spun bearing
Hey fellas, a couple of questions on spun bearings. One of my buddies owns an 87 Supra 7MGTE. Couple weeks ago his engine seized and he diagnosed the problem to be a spun bearing from a ruptured oil line. Hes selling the car now and Im considering taking it off his hands. The problem is I really dont know the extent of the damage to the internals nor does he. What parts commonly go bad in spun bearing cases? I read a couple of threads and some mention that crankshafts and rods are commonly warped beyond repair. Should this be the case, is the bottom end worth rebuilding or should I be thinking about possibly throwing in another 7M instead? He has it listed on craiglists, other than the motor the car is fine, I actually got to see the car when it was running and happen to see it run as well. It ran good up until this point. What are your thoughts, what would you do?
91 Supra is offline   Reply With Quote
