Old 10-23-2007, 04:20 PM   #1
Jrew
Jrew's Avatar
Jrew is on a distinguished road
Default Car Died...where to start?
Ok went to start my car this morning and nothing... it cranks but won't start. I tested the battery...its fine. Now, i have yet to replace the spark plugs since i bought the car nearly a month ago and i have had some weird start ups in the past on a cold start. Typically the car would crank for a bit then finally start up but i seemed to need more time than usual to fire up. Anyhow, now it won't turn over at all. I was going to just replace the plugs to see if that fixes it, and if it doesn't then i have new plugs i suppose. If that doesn't work however, where should i go next? Thanks for the help
Jrew
If you're going to strive, strive to be the best.
Jrew is offline   Reply With Quote
