Originally Posted by kwnate
If its seized expect alot of damage. Might be better to buy a new bottom end and rebuild off of it. I'd tear it down and look first though. $1800 at the most imo. Yes I looked at the ad. It will take 2-4,000 to rebuild depending on how much you can do on your own and how well you rebuild it.
So its definitely not going to be easy nor cheap to get this thing up and running again. Its looks like perhaps buying a JDM 7M or just going 1JZ is a better option considering its going to cost 2-4K(Performance parts or OEM quality?) to rebuild any damaged components found on that cars bottom end. How do you feel about that approach? I imagine
you'd probably just tear this motor apart and throw in some beefy race ready parts and pump out another 800 horses like that blue beast of yours; However, for someone who is still learning about these cars mechanically, would you recommend I just buy another motor or really work with this one, get some help with it, and just go all out on it?? Thanks for your thoughts man
