Old 10-26-2007, 03:43 PM   #3
Supra2NR
Supra2NR's Avatar
Originally Posted by supraman121
I say a video of someone that didnt a turbo convsersion and he said he was boosting 9.5psi on a stock ct-26, i really probly would boost more then 6psi if the turbo is an upgraded turbo... Also were did you find a na turbo conversion kit or did you buy a turbo upgrade kit for the 7mgte motor and does it work with the stuff that came with the upgrade kit?
smaller injectors + high compression piston + more boost than stock 7mgte = not the best mix than you can think off
