The 7M-GE has 330 injectors I think, but the stock 7M-GTE injectors are 440s.
I'm pretty sure both the GE and GTE are the same excluding turbo oil retern and feed and compression ratio.
To lower compression a small amount you can get a thick metal head gasket.
"Stuck in the 80's"
