Originally Posted by Chambers
Well I'm doing a NA-T and wondering about the resistance on the turbo injectors, becasue if they have a resistance on the turbo car, they would rock on the NA with no resistance.
you shouldn't have to worry about the resistor pack if you are going to put the turbo injectors on the n/a. the n/a's also have resistor packs wired into the hareness so its just plug and play, a direct drop in
