i think that you need to def check fuel pressure more then spark what sounds to me like its flooding the cylinder. supras come with a stock fuel pressure regulator and yours might have gone bad and when you are gunning it as i would expect that the fuel pressure regulator is malfunctioning and its causing it to flood the cylinders. hook up a fuel gauge and see the fuel pressure and make shure its around what it should be. the rev it up to 4 grand and see if it increases. thats what i would check first.
