Did I read that right
"They put the oil cooler was installed to get oil to the turbo"
You gotta be kidding me
And a the 7mgte oil pan has the return? Since when
Ok the oil cooler is pretty self explainatory, it cools the oil
Kinda like how the radiator cools the water,
And an intercooler cools the air, so you get my point
You need to find a oil feed for the turbo, since I would assume the same location is not tapped on the na block
And the 7mgte oil pan does not have a tap for the return
Maybe bigger for more oil capacity
The return line is tapped into the block, which isn't on the na block,
With the coilpack you also need to get an igniter, since they're a completely diffrent ignition system from the na
And there's a reason why the turbo is watercooled, what that reason is, idk and don't care ,I got a diffrent setup now, but they designed it that way, and I can only assume it will work more efficiently and properly if you keep it that way
Get a thermostat housing from the deal that's for a 7mgte
If I miss sumthing, or mispelled, my fault
Im at work right now
