maintenance
At 90K miles (60K + 30K), I would only replace the air filter, oil, and oil filter per the schedule at 30K.......assuming you did all the required stuff at 60K. You will note that the LSD oil change is recommended at 40K intervals so you might consider that if you didn't do it at 80K.
