Should be able to swap a turbo tranny into a N/A. If you get the R154 with the bellhousing for the 7MGTE they have the same housing. The only problem you will have is the driveshafts are different. But that is easily fixed if you get a solid driveshaft. I would say yeah go ahead and swap it but if you just wanna W58 I have one you can have just come get it. As for the different lengths on the W58 and the R154 they are the same length I measured because I wanted to know before I put my 1JZ in.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
