Old 11-13-2007, 04:40 PM   #11
tsupra89
tsupra89's Avatar
tsupra89 is on a distinguished road
Originally Posted by 86SupraMan
hmm.. ok maybe tranny will need to wait till i get more cash lol, 1 more question ive bin wondering about, ive bin lookin at aftermarket throttlebodys, but theyre all for the GTE, would they fit in the GE? or would i need one specifically designed for the GE?
The TPS is mounted on the throttle valve body and sends a varying voltage signal to the ECU based on throttle valve position. The ECU can then adjust fuel delivery based on acceleration, deceleration, full throttle (WOT) or idle. The TPS inputs the ECU through terminal VTA.
the throtle body off a 7mge wont work on a 7mgte im shure it will bolt up but the routing is totally different as in the picture so your best bet is find one for a 7mge
89 Supra Boosted 11psi
lexus afm
k&n air system
aeromotive fuel pressure regulator
walboro fuel pump
stage 3 weitght reduction
koki style tail lights
silver and black 2 tone paint
Enkei rs7 17" 17.5lbs each
hankook ventus hr2's 225/45/17
apc hood pins
yellow fogs
Soon To be
Megan racing seats, roll bar, either takata or sparco harnesses
tsupra89 is offline   Reply With Quote
