Old 11-13-2007, 08:36 PM   #2
Chambers
Chambers's Avatar
Depends on if you get a stand alone or a piggyback fuel controler. Piggyback require a signal from the ECU to alter so you can tune your vehicel, a stand alone will just simply replace the stock ECU entirely, good luck.
"Stuck in the 80's"
