Originally Posted by mkiiisupra
i removed the accordian hose and was able to see that it connects to a valve assy thing on the bottom left pulley thing.
which is broken on the steering pump and on the extra one, way to go toyota make a 175 dollar part outa plastic YEAH!
anyways can anyone shine some light on where that metal pipe off the bottom of the charcoal canister is saposed to connect to?
The pipe on the charcoal canister should just vent into the air but it connects to a small hole in the frame. That is how it was on both of my 87 Turbos and also the peice that is broken is on the Powersteering pump is a valve that will go bad after some time.
Is your powersteering hard or does your ps pump make noise?
