This is what you call your power curve. Your power will always peak then die off. That is kind of normal with a n/a really mine did the same thing. Now with a turbo you will feel the lag in the beginning and then it will also peter out on the top end unless you put a boost controller on it to take care of that.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
