Originally Posted by Jpw
I am in the market for a Supra, but dont know what is the best year or engine to look for, i am looking to spend around 25-30k for this Supra...
All the model years ('93.5-'02) are pretty much the same, except '99-'02 only available in RHD in Japan.
...It has to be a 6-speed tho, witch is better? Twin turbo or single turbo?...
The Mkiv Supra was never sold brand-new from Toyota with a single turbo. The only way to get a single turbo is to buy a Supra that has been modified, or to install it yourself. Since modified single turbo Mkiv Supras tend to put out much more power than a stock TT, you could say that a single turbo is "better".
...i am looking for gas milage around 18-25 MPG...
Then you'd better not get a modified single-turbo Mkiv. The more power you ask it to put down, the worse your gas mileage will be (in general).
...And how many miles are these engines good for till they need to be rebuilt or replaced?...
Depends if the Supra is bone-stock, or it has been modified. A bone-stock Mkiv Supra driven 'normally' can easily exceed 200K miles.
...what the safest HP you can pull out of this engine?...
Depends how many miles you want it to run before you want it to be rebuilt or replaced.
The more hp you ask for, the harder it will be on all of the components (including the engine). With a big single turbo, the oem (unmodified) engine itself can put out 850rwhp through a 6spd (=1000hp) safely, as long as it's using high-octane race fuel when putting out that power level. That said, don't expect the engine to last 200K miles if you're laying down 850rwhp 3-4 times/wk.
