you have to take the glove box out, and then there is a cover that you have to tear out, then you will see 2 things a skid control and the ECU, im guessing that the skid control is for ABS or somthing cause we definatly dont have traction control :P
7MGTE - 500hp  never dyno'd
fidenza cam gears
