hmm that way you routed it seem really complex and lots of bends, i'm trying to keep it simple not insane :P
what i'm trying to figure out is why did you cross it when you could have done a straight shot from the TB to the passenger side of the intercooler then go from the drivers side up?
plus i see you relocated your battery and your fan in missing or just cant see it. and is that a cusco oil catch can? and could you not rotate your turbo?
![](http://i40.photobucket.com/albums/e209/lone_anarchist/0106081757small.jpg)
7MGTE - 500hp ![X Fingers](images/smilies/x.gif) never dyno'd
fidenza cam gears
