power steering pump blowing fluid
OK Guys,
I will be running an 87 NA supra on a road race course for 8 hours, 2 days in a row. Has anyone had any problems with the powersteering fluid getting foamy and burping out - thereby oiling down the tires as well as the racetrack.
This is a common problem for other cars - and we typicallty deal with iotv by revalving and rebuilding the pump to give lower amounts of boost at higher RPM - but with this high reving motor i can see potential for a bad problem with this issue.
Since I am limitted to 500 bucks - the easiest solution may be to remove the powersteering pump - and run it with no powersteerring - which is typically not a problem on a road course.
Anyone have any experience with this?
Carl Johansson
