Originally Posted by Chambers
It will work you just have to make sure you rewire the neutral safety switch to the clutch switch so you can start it correctly, if not you will have to run a manual ignition switch/button.
wrong, there will be splicing involved to bypass the neutral safety switch, there will be no clutch start switch, and to wire up the reverse light, the auto ecu can be used but the o/d light blinks
