Well for starters screwed all the way in or out. That will make a difference because out is slower and in is faster. Also do a check in the Online manual on here for the test for the Idle speed control valve, the adjustment for the Throttle position sensor, and the proper adjustment of the idle screw. Hope that helps I dont deal with 7MGTE very much so I dont know it off the top of my head. If it was a 1JZ I could tell you quick.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
