Old 11-29-2007, 06:41 AM   #1
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
maybe you got water in the spark plug holes i would missfire and lose power when i had that when i would almost reach 4-5k but i got a 7mgte might be different but i replaced mine and havent had a problem ever since or oyu might have a vacuum line unhooked or a leak check all your connection and compare to the tsrm to see if theyre the same
cyanide-is-a-way-out is offline   Reply With Quote
