Also sounds like you have your boost controller set to high. When you put it in did you make sure that you connected the hoses off the wastegate the correct way. If you get them backwards then you will not get anything but the wastegate open all the time and no boost which sounds like what you have going on. Plus it is a good way to know something you added did it when it happened after you put the boost controller.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
