Originally Posted by Supra2NR
i got a question
i checked the replacement afm
they said its a copy of the lexus afm
which wont come with any of the electronics of the lex afm itself
its says you have to reuse the honeycomb and the black box?
doesnt the lexus afm has diffrent electronics than the ones that came from the 7mgte?
or is it jus the size of the afm that changes?
weird!?!?!
mmm like i said the houseing of the AFM is bigger on the lexus version compared to the 7m version.
replacing the honey comb? uh i dont know if you can even do that, hell if my honey comb broke i would just go and get another AFM
and the black box is the sensor itself, and yes totally different, just has the same connection as the 7m, so its just a plug and play
7MGTE - 500hp
never dyno'd
fidenza cam gears
