Originally Posted by west_side_supra
weird!?!?!
mmm like i said the houseing of the AFM is bigger on the lexus version compared to the 7m version.
replacing the honey comb? uh i dont know if you can even do that, hell if my honey comb broke i would just go and get another AFM
and the black box is the sensor itself, and yes totally different, just has the same connection as the 7m, so its just a plug and play
The Lexus AFM does NOT come with the black box sensor. It says to use the original 7M-GTE box/sensor. So it appears all we would be buying is the metal AFM housing and transfering the original honeycomb and sensor to it. Maybe the original sensor detects more air thanks to the larger AFM housing, compensates for that in combination with fuel cut defencer allowing more fuel, and the now larger injectors gives more fuel. Result for me I hope is...larger turbo + boost controller + fuel cut defencer + larger injectors + larger AFM housing + HKS intake = more HP.
Does this all make sense?
