Originally Posted by west_side_supra
yea cyanide knows what i'm talkin about, he's seen my car. just take a look around, ebay is your best bet though.
So back on the injectors, this one site I went to talks about top feed vs side feed. I thought we had top feed? He wrote me...and also check this link and give me your opinion...please...thanks in advance.
Fuel Injector Clinic:Toyota Top Feed
The injectors listed below are all low impedance/peak&hold top feed injectors so you will have to convert to a top feed fuel rail to run them. This is typically less expensive than purchasing side feed injectors, since those are scarce and expensive. Also, once you have converted to a top feed fuel rail, a lot of other injectors will fit if you upgrade to the next level.
We sell a kit with 6 x injectors, a fuel rail, fuel pressure regulator and all the bungs and harness pigtails starting at $710.00.
550cc good for 360 wheel hp or 425 crank hp
650cc good for 425 wheel hp or 500 crank hp
750cc good for 485 wheel hp or 575 crank hp
850cc good for 550 wheel hp or 650 crank hp
950cc good for 620 wheel hp or 725 crank hp
1050cc good for 680 wheel hp or 800 crank hp
1150cc good for 750 wheel hp or 880 crank hp
