yes we have top feed, as for the numbers for hp and crank hp i dont know how accurate that is, maby for those injectors though. again i highly recommend the PTE or RC injectors. they are the best your going to get. as for size i recommend 550cc - 780cc
7MGTE - 500hp  never dyno'd
fidenza cam gears
