Old 12-15-2007, 12:48 AM   #1
Supra2NR
Supra2NR's Avatar
Originally Posted by Chambers View Post
If you use the oil pump and pan from your old engine it should then fit, before I bought my car, it had a JDM 7M-GE put in it and I can only assume they ran into the same problem, The engine wont matter if its pre/post 89 because a engine is an engine, its the wiring that wont work, I see you know that but it can't hurt in clarification.
From my knowledge and someone correct me if I'm wrong, there was no JDM MKIII Supra that came NA, the NA 7M came from another JDM car, I can't remember witch but if the pan an pump are diffrent then just use your old parts, but I would just spend a little money and get a new oil pump for a 7M-GTE. Hope this helps.
doesnt the post 89 use a diffrent crossmember?
i remember pple saying this cuz they say you can mount a 2jz motor without changing them
they also use diffrent mounts
cuz i had to reuse mine when i did my swap
