the common thought is to replace the head gasket with a metal head gasket , torque the head down better than factory specs and you are all set . however let me tell you thats bullshit
the two surfaces need to be flat flat and smooth as glass . a guy will pull out the head and have it finished, bolt it back on and call it a day , but what about the block . the block most likely gets zero attention
