Old 12-17-2007, 10:21 PM   #17
Supra2NR
Supra2NR's Avatar
Your setup works bro,
What I want to in addition is
Put a switch in between where I tapped the black and white wire and the igntion itself, so even if I leave the keys in the car they wouldn't be able to start it unless the
Headlight washer is used,
So this way, in case the washer switch screws up while im on the road I can flick a switch and I can start the car with no problem
