the transmissions are interchangeable. the only thing that is different is the brackets that go from the block to the trans. i put the R134 on my non turbo motor. all the bolts line up all you need is the brackets. umm im not really too sure about the differences in the trans. i did 150mph and the rpms werent redlined. i know it will pin the speedo at 160 but im not sure what it will top out at.
1986.5 MKIII(7MGE soon to be 7MGTE)
