well with the 90 motor came with diffrent motor mounts
you need to find motor mounts from pre89 motor
with the wastegate, you need to replace it
idk i never heard of a divorced blow off valve
jus find a used ct26 turbo and take the wastegate off of it
you cant jus use external wastegate
since you will need another manifold for them
and i think your talking about a divorced downpipe
you will need that custom-made for ya, if your using the stock manifold
or maybe sum company makes a divorced downpipe that bolts to our manifold
cheap upgrades to the motor
ranges from intake, exhaust,better ignition system
lexus maf, 550cc injectors,boost controller, to raise the boost
hardpipes for the intercooler
clean the intercooler, cuz most likely itll have oil and 20 years worth of dirt in it
i most likely missed something, but feel freeto add on
