I don't know much about the supra brakes, but I can't imagine the 4runner ones are much bigger, at least not until 2002.
I have an '85 truck and know about the older 4runners and trucks, the master cylinder isn't any biggger. One from an fj80 should bolt up, but it has the same size bore (1"). You can get those from marlin crawler, they sell them for 4x4's. (say that 3 times fast!) They also sell calipers for 86-95 4runners if thats the correct year to fit on the MKIII.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
