The injector cables? Do you mean the spark plug wires? The distributor cap should have numbers on each ear for which wire they go to.
Also most toyota distributors have lines on the gear and then the body to line up before installing. (with the engine at tdc, on the #1 cylinder compression stroke.)
See here:
Page IG-17
MK3 TSRM On-Line
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
