OK you want to know what kind of things you will run into. Ok the gear ratio isnt a big deal your speedo will just be off a bit mine is like 3 miles per hour fast. You will need the three plugs for under the dash and the one from under the hood. Seems like you have everything else handled but just remember because I have seen everyone run into it your tach will not work best to get a aftermarket one and wire it to the small wire on the ingitor box the blue with a red strip wire to get the signal. Oh yeah get a solid drive shaft because unless you have a R154 shaft then your up a crap creek. Change the oil check out the timing belt good and also check your ECU board and replace all five of the capacitors or you will regret it. After that have fun because it is a big change from the 7MGE especially when you step on it I would get a walboro it will save you from leaning out at top end. Any other questions send me a PM.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
