sensor?
I recently bought a JDM 7m-gte and noticed that on the thermostat housing cover( after the thermostat), instead of a vacuum thermo switch for the evap, there is a looks like a temp sensor 1 wire type. Whats this sensor for? Do I just remove it and not worry about it. I think the only coolant temp sensors need is for the cold start and normal coolant them sensor.
