Depends on the year of the motor and of the car.
Should have one two prong sensor for the ecu, one two prong for the cold start injector and one one prong for the temp gauge in the dash, unless I am forgetting something. I would either use the t-stat housing from your old engine, or swap the sender for the evap vsv.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
