Originally posted by ddmcse@Jun 9 2005, 03:47 PM
replying to this post may be too late
however i want to warn you:
appling more boost without planning will result in a blown head gasket before you know it . and btw a manual controller is fun at first but you'll find boost levels ranging all over the place
using a stock boost gauge is not a good idea it only goes up to like 8 doesn't it ? once you start getting fuel cut off you might want to back off a little . atleast until you have an accurate measurement of boost
thanks for the reply. so what is the stock boost set at? isnt it safe to boost 10 from the 7 stock if it is 7? i need some instructions on what to disable because no matter what i do its still only boosting 6-7psi
