O2 sensor problems will ususally happen constant at high speed/ high load conditions.
Intermittent hesitation could be the afm, or the tps, but should have a code pop up with te and e1 shorted. Could also be fuel pressure problem. Resistance checks might show all good unless you can test it when it is hesitating, which would be difficult at best.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
