Well first off if your charing system is charging at 18 volts then your voltage regulator is probably shot, its not suppose to charge that high. Second, if your battery is dying overnight then you probably have what they call a parasitic draw, something in your electrical system is pulling battery power constantly, such as monkihead said a short in your electrical system.
