Thread: Won't Start
Old 01-14-2008, 01:28 AM   #10
mkiiisupra
you give me to much credit lol, in 2 days when im off im buying a timing light and doing the Ignition timing..
I will try your WOT thing and the TPS unplug as well, i do appreciate all your responses. I probably will figure it out, but that is only becuase of people like you, and others in the forum that take the time to post replies
Any ways all the timing instructions are unclear on a couple things...
Where is the CPS that i have to loosen to adjust the timing. and do i loosen it before i start the engine?
Something else i just thought of. If i start the car with the TPS unpluged this will put my car into limp mode since its getting no information from my TPS, but isnt the ignition timing based on the TPS, so i adjust with it unpluged and soon as i plug it back in and try to start i would have the same problem?
1990 Toyota Supra Turbo A/T
