jdm 7mgte cam sensor wiring...
I have a huge favor to ask of anyone with an 87 usdm 7mgte. Can you give me the pinouts/wiring colors for the cam position sensor plug on the engine harness side? I mean which wire color is top right, top left, bottom right, and bottom left. Thanks! It would be greatly appreciated!
edit: I have used search, and have looked at several TSRM's online, but they all list the wire colors the same as the plug in my hand (from 91+ jdm replacement engine), the existing one on my engine has been replaced (it dissolved so I temporarily wired in a flat-4 trailer connector). The 86.5 supra wiring colors are slightly different. Thanks!
Reason: to explain i'm not a stupid noob that doesn't use search
