Originally Posted by CyFi6
ive got a leak but im not ready to spend that kind of money on a hose. Anyone know if you can put together a hose using those hoses/fittings from summit racing for a little cheaper?
You can take the high pressure hose out, and take it to a hydrolic hose company who can rebuild the rubber portion for $20-30 ususally. I've done that to quite a few p.s. hoses. Its really not that much cheaper, but since you are using the old metal fittings, they will work better.
maybe.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
