Old 01-15-2008, 10:50 PM   #10
SleepysSupra
SleepysSupra's Avatar
SleepysSupra is on a distinguished road
Try resetting your computer. The way you do that is to remove the negative battery cable for roughly a minute and then reconnect it. It doesn't fix it right away. You have to start it and keep it running for a while cause it will try to die on you again. THe problem is the computer needs to relearn after a cleaning that good. It has all the old data stored from the way it ran before the cleaning and after the cleaning air flow is vastly improved. It will take roughly 15 to 20 minutes for it to re learn. Let me know if that helps.
SleepysSupra is offline   Reply With Quote
