Everything is possible.
Are you trying to use the getrag 6 speed with your current 7m engine?
As far as I know that is not possible, I was told by a mechanic familiar with these cars, that to swap in a 2jz, you have to have the getrag 6 speed, so I would assume the opposite is also true.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
