Bic DDP
How many of you with the bic DDP daily drive your cars?
How loud is it and can you drive it without getting tickets for noise?
I really think thats what I want to put on my car, but not if I can't drive it on the street.
I also have to pass emissions every two years, so need something that will pass a smog and visual test. I'm not too worried about the visual, I doubt they will be able to see anything under there, but I don't know how close they look.
I don't want to do the optional reconnection back into the exhaust, because I want the exhaust noise, but only when I floor it.
So I guess I want to know how loud is it before full boost, and can you control the sound by the way you drive?
Thanks, Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
