Old 01-16-2008, 04:56 AM   #1
83restomod
83restomod's Avatar
83restomod is on a distinguished road
go over to celicasupra.com there are write ups on the 5 speed swap all over the place.
manual trans
clutch pedal assembly
slave cylinder
master cylinder
clutch lines
trans crossmember
5mge flywheel (get it resurfaced or new)
5mge clutch assembly
driveshaft from a manual car
your center consol will be fine
you may want to get a maunal brake pedal assembly casue its smaller then the auto one.
good luck
83restomod is offline   Reply With Quote
